Omron NQ5-SQ000-B HMI
bigvern10
Nov 2005
Burnley
Chaps,
I have an Omron NQ5-SQ000-B HMI, and I need to back up the application, firmware and fonts to a memory stick so I can program our spare unit.
My question is: how do you stop an application from running to enable access to the memory stick menus? The manual says to set system bit S037 to 1. Is this done through CX-Programmer connected to the PLC or through NQ-Designer connected to the HMI?
The reason I'm using a memory stick and not the NQ-Designer is that the firmware version of the HMI is 2.2 and our software downloads firmware 2.23, which appears to stop the RS485 capability of the coms port...
Thanks in advance!
Thanks for your reply. I've read the Quick Start manual, but I still have no idea where to set system bit S037 to 1 to force a memory stick read. I've looked through all the menus on NQ Designer and CX Developer with no success... :(
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
202
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
83
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
142
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
287
