Omron NT31C - Uploading a Screen
Dstew
Apr 2022
Saskatchewan
Hello,
I have an Omron NT31C that I am trying to upload a screen to from my laptop. The software on my laptop is NT-series Support Tool ver. 4.87 and Translation Support Utility ver. 2.00.
I made a simple screen using the NT-series Support Tool. Then I tried to upload it to the NT31C using the same cable that I used earlier to install the software - Omron Direct Access (E) Version 3.23.
To start the upload I select "Transmit Mode" on the Omron and select the correct com port with NT-series Support Tool. At NT-series Support Tool I select Connect -> Upload -> Screen. At this point I see a brief flash of information on the Omron screen but at the NT-series Support Tool I get the following error "Memory Access Mismatch, Communication Aborted".
I believe I am missing a step which is to select Tools -> PT Configuration -> Control/Notify Area. Am I on the right path? And does anyone have an idea of what PLC Address to use in the following:
- PT Control Area?
- PT Notify Area?
- PLC Address?
Any information is greatly appreciated.
I'm not using a PLC. I am trying to create screens on my laptop with NT-Series Support Tool and then upload them to the Omron. Just trying to learn that part of it.
Notify and Control areas are locations in PLC memory that allow you to control the screen.
Typically for an Omron PLC the Notify and Control areas were either H or D memory.
I have attached a memory map file showing addresses and range.
gtsuport
gtusport
I looked at the chart you posted. I do not understand how it applies.
I did make some progress but what I ended up doing to solve the "address" error in PT Configuration was the following:
PLC Address: 00004
PT Notify Area: 00008
Window Control Area: 00016
I read through the manual but did not find this specific information. Instead I found a couple discussions somewhere on the net. Basically, a little dumb luck.
hi hello every one . i have a Omron nt31c hmi and i want to connect with ls plc XBC DR60SU via rs232 . do any one now how ?? secondly :i have...
196
Hello I have salvaged a Omron NT31C-ST141-EV2 from a piece of LAB equipment. I put power to it and the screen lights up with the words "Please...
4,906
Hello, could you help me please with Omron panel and program NT support tool. I have 2 panel NT21 and NT31C all panels are empty, no program...
1,646
Hello could you help me please, how can I switch Panel Omron to basic menu. After power up lighting System Initializing, I need upload program...
1,941
I'm using an Omron NT31C HMI and a C200HG Omron PLC. I tried downloading data from the PC to the HMI (using Port A) and it was successful. I can...
9,473
