Omron Nt620c system menu problem
Danil
Jun 2020
Russia
Hello, omron nt620c cannot access the system menu. After loading the system program and initializing, the message "No direct information is set !!! Please use the Support tool to set the PT Control Area and the PT Notify Area." Tapping on the corners of the screen does not help. SW switches are installed in accordance with the manual. When you try to download the program via NTST, the message "Time out error." What is the fault?
Dear friends,my level of English is very low, I tried to describe the problem as simply as possible
I cannot remember exactly but I believe when it first boots there are 4 touch switches in each corner you need to press two of them at the same time I think you have to hold them for a second or two. Also check the dip switches here is the manual:
https://www.myomron.com/downloads/1.Manuals/HMI/NT/v033e1-5 NT620S+NT620C.pdf
Hello! Thanks for your help. I tried to do this, but the panel does not respond to clicks. dip are set according to the manual. I tried installing different versions of ntst. there are no changes. I don’t know the breakdown history, as far as the panel was brought after attempts by other engineers to fix it.
I'm trying to work with an OMRON NT620C touch panel. When I power it up it comes up with a message: "No direct information is set! Please use the...
3,765
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
132
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
100
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
