Omron Pass through PLC Comm
TJBK
Jan 2021
Newmarket
I've been given a line that has several sysmac c200Hx PLCs. The First station Im trying to wrap my head around has a NS8 HMI. I'm using Cx-one software.
I wanted to communicate though PLC to PT. Can't get it to work. Ive been searching for info but i feel like this might not be possible. I'm new to the omron world coming from AB. Any insight would help
I've had trouble with that in the past. Is there a good reason you need to pass through?
If it's Ethernet, you can connect directly. The FINS Source Address is your PC and should be different than the FINS Destination Address (which needs to match the NS setting). The Node in most cases is the last octet of the NS IP address.
If you get the settings wrong, the time out is very, very long and it needs to time out twice. It's a real pain.
Hi all, Is it possible to program an Omron PLC remotely passing through another PLC? I think the picture describes the question better... And...
1,884
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
75
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
71
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
211
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
