Omron PLC-need to force a bit
Robert K
Jun 2004
Hello,
Since it's been almost 4 years since I've used Omron PLC"s, I can't seem to remember how to force a bit using a handheld Omron SYSMAC C200H-Pro 27 E Controller.
My first problem is remembering how to count or get the bit its self. I know the bit I want to turn on is on Output Module 4 channel 2. The number on the wire going to that bit is DO15.
So my question is how do I force that biy on and off?
Thanks for any info.
Robert
The information regarding the output module is sketchy at the very least.
If by module, you mean slot 4 and by channel, you mean bit 2, then the address could be 00402. If that is really the case, the keystrokes are:
<CLR>
<CLR>
<CLR>
00402<MON>
<SHFT>
<SET>
To Unforce:
<SHFT>
<RSET>
Before you proceed, I think it would be wise for you to tell us the Model of the Omron PLC and the Output Module Part Number. Could make quite a difference in the addressing.
PLC Model
Hello,
The PLC model is an OMRON C200H and yes I mean slot 4 and the second channel on that slot. The output module is an Omron C200H-OD212.
And yes, from what you've posted here, that looks familiar..I thought it was 00402 as well but couldn't remember.
Thanks,
Robert
All is working now..
Hi Jay,
Thanks for the replies and link to the manual. I got it figured out this morning and found the problem and resolved it.
Thanks again,
Robert
Hi, I don't have any formal education background with PLC. I am learning PLC by myself. I have CJ2M CPU34 unit and CJ1W-DA021 unit. I would...
1,238
hello guys I'm having problem in pid in Omron cp1l plc I have program . I'm getting alarm when I execute pid
2,811
Good day all, Newbie here so I'm practising my posting skills. I have a problem with one of the Omron C200HG PLC''s in our plant. This particular...
1,468
I have an assignment where I have to power up the motor for 1min and off it for 1min and it goes on and on until i toggle the stop button. I...
1,875
Hello guys i am you lil borther Ali.......i want to control control a DC motor speed control (PWM ) with omron plc i found cp1e-na20dt-a and...
2,230
