Omron sl5500 + nx102-9000
jaiiyer
Dec 2022
Vancouver
I am building a CIP safety using OMRON.
I have imported the EDS file (non safe) from KUKA and used it as a target device on the for PORT 1 of NX102.
I created a EDS file on the safety PLC side under Connection Settings using the information from KUKA safety side
When i try to transfer the program to the Controller it transfers everything except for the Ethernet IP settings on the NX102 side. The "Transfer to Controller" button is greyed out when I go online. So my ethernet setting are not getting transferred to the NX102.
When I uncheck the "Do not transfer the EtherNet/IP connection settings" the transfer fails. But when i check the box the transfer goes through.
I have attached pics to give better idea
I have opened a ticket with OMRON and they had a look but couldn't give me an answer. They are still working on it.
Has anyone came across this situation where they could transfer everything but the Ethernet IP settings and the transfer to controller button was greyed out?
Thanks for reading through the post
Sysmac Studio NX102 + SL5500 Ethernet IP settings.png Sysmac Studio NX102 + SL5500 safety connection settings.png Sysmac Studio NX102 + SL5500 synchronization error.png Sysmac Studio NX102 + SL5500 synchronization success.png
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
117
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
86
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
215
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
87
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
157
