Omron SSS (LSS) on Windows XP
Ianc
Sep 2004
Hello, looking for some help on Omron SSS software.
I am trying to run this software on an XP professional lap top.The program runs OK and connects to the PLC (after creating a DOS partition for it to write it's files to), but when it transfers the program from the PLC it takes 5~10 mins to convert a program with only 3 rungs in it, the program then disconnects from the PLC and you have to re-connect it. These problems are annoying rather than critical but i would like to see them fixed.
Before anyone suggests using CX or Syswin (we have both on site)- we need to use SSS to support legacy PLC's, it was only a recent PC hardware upgrade that created the problem.
Thanks in advance...
Actually I posted to keep up on this thread. I have LSS2 but havent tried it on an XP machine yet. Have you tried creating a DOS Boot partition and running the LSS from there?
If there's no resolution here I'll try it out myself later, when I get the time.
Mike
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
202
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
83
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
145
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
287
