Omron ST shift instruction
andepand
Jan 2017
Amsterdam
72
Hello fellow enthousiasts,
I having a small Structured Text problem on an Omron CJ2M using CX-programmer.
I’m trying to use an SHL instruction but I can’t get it to work because I have no idea how to make it shift.
The syntax sort of looks like this: A:= SHL (B,C)
A being the outcome
B being the word I want to shift left
C being the number of bits I want to move it
But what makes the instruction shift, where do I put my clock pulse or machine cycle pulse?
I tried placing it in an IF statement:
IF P_1s THEN
A:= SHL (B,C)
END_IF
The compiler agrees with the syntax but no output whatsoever on A:=
What am I missing here?
Thanks in advance!
Greetings,
Andy
Well
It is.
And even if it wasn’t, I still don’t know what makes the bits shift.
In the ladder instruction there is an input (ST) for it.
I forgot to mention that it’s written inside a Function Block.
Creating a bool named trigger didn’t work. I suppose it has to be assigned to my shift instruction, and that’s my whole problem
P_1s is high for 0.5 sec so any bits will shift through very quickly.
I'd oneshot it.
And I would ignore osmanmon's suggestion. That won't help.
Pp
I figured.
For testing I leave B high (changed it to a BOOL for testing purposes), so I think it should keep outputting 1’s as long as I do that.
Maybe I’m looking at it wrong. I’m treating this instruction as a regular ladder SFT instruction and probably I shouldn’t.
Anyone out there with proper Structured text knowlege?
(Note: also posted at MrPLC) The results from a Function 03 (Read) splits the high/low byte of the returnd 16 bit words. Neither of the 4 bit...
3,260
Hi all. Say I'm using address W1 as my starting (and end) words in the SFT(010) instruction; does anyone know whether it's ok to "parallel load"...
4,596
I am using WSFT command to collect different process variables. I am displaying info on NS touchscreen. Is there a better way to do this? Maybe a...
3,459
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
84
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
71
