omron SYSMAC C60K PLC communication cable
hi,
can anybody send me the link for software ?.
the cable i should make is DB25 RS232 CABLE OR CV500-CIF01 toolbus programming cable ? . plz make clear both have 25 pins. ?
Thank You.
Thank You.
You would have to purchase the software somewhere. I wouldn't bother with LSS. Look for either Syswin (old) or CX Programmer (new). You may have to contact an Omron distributor.
You're also going to need a Hostlink module as already mentioned. You will not be able to interface to the PLC without it.
Another possible alternative is to reverse engineer the system and install new PLC.
I have a customer in the Baltimore area with an Omron PLC connected to an old CNC. I will be upgrading the CNC and want to eliminate the Omron by...
1,429
I have a project where an existing Omron Sysmac C60K PLC needs to be modified to control some new equipment and two 0-10 volt analog outputs are...
3,733
2,634
Hello everyone. I have a Omron Sysmac C60K that I will be upgrading to an AB SLC 5/04. The problem I have right now is I need to pull out the...
7,782
Hello,I am new to plc`s. I have played with AB plc`s(about 1 year) so i am still wet behind the ears. My problem is a OMRON SYSMAC C60K-CDR-D plc...
9,504
