AutomationTechBrian
I'm taking some time today to learn how to edit a customer's Omron PLC program. My customer has a machine that is used infrequently during the day, but the machine is powered on all the time. There is a safety air valve on one of the outputs that is powered on all the time that keeps the measuring equipment from being damaged if air pressure gets too high. I can understand why the original programmer had it normally activated, but the downside is that the valves get really hot and end up failing prematurely. I'm going to put a sleep function into the program with a timer tied to the inputs. To wake up the machine, you activate one of the two hand-sensing inputs, which starts the timer. While the timer is timing, the valve output is active, and the inputs revert to normal function. ...pretty simple stuff. I gave that information because I don't need a complete CXOne lesson. There is a timer that should be capable of timing 15-30 minutes, and a couple of timer bits, like Timer-Timing. But, I'm in CXOne for the first time, and some of this is looking a bit primitive (compared to today's programs). There is certainly a learning curve to go through. For instance, I noticed there are different timers for timing different lengths of time. When I find a video on YouTube for CXOne programming, I can't help but wonder if the information is still applicable for this old, legacy PLC.
I was at the customer's location last week and uploaded the program. They had a spare PLC for me to take home and learn on, which is awesome. My coffee is brewing, and when it's done I'll start digging into what is needed to make the program edits. There could easily be some "gotchas" here. After uploading, I remember looking at memory addressing, and the check boxes for looking at the different memory types, and I'm wondering how that is managed. When I upload and download, do I need to do something special to capture those locations?
So this is more of an open-ended post. For those familiar with this legacy Omron programming, are there any tidbits of information that would be helpful in learning how to accomplish the program edits?
