Omron Sysmac Import Project and adding IO Link
bagged2drag
Mar 2011
Milwaukee
37
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices attached (IFM 1332, and some IO link sensors). I have the backup files from the integrator (.smc2 files). If I import the .smc2 files into Sysmac Studio and open the projects, will I need to manually add any of the .esi and IODD files to the project, or will they be loaded in automatically from the backup? The integrator alluded I will need to manually load the IODD files, but the IFM 1332 devices, for instance, appear to be loaded ok.
Also, I have some banner sensors that are IO link. if I do need to add the IODD files for those devices, where do I add them? I assume these are IO slave devices? I don't see any configuration for them in the project, but again, the integrator alluded to the fact I will need to load these IODD files.
Thanks,
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
508
Hi everyone, I am trying to program a function block to copy the variables obtain from Ethercat into a structure on a NX1P2. Since I cannot...
1,117
Hello all, I am attempting to sort a selection list via 'part-selection' buttons. Ex. a certain type of model is selected, I only want to have...
1,356
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,152
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
758
