Problem with delayed switch on of omron sysmac cp1e
barsergey
Feb 2022
Tashkent
Hello.
I have a problem with omron sysmac cp1e controller delayed start.
The controller has been working on the punch press since 2016. Recently, there was a problem with turning it on. After power is supplied to the machine, the controller does not turn on. Voltage is applied to it (checked), the voltage characteristics are normal (checked), but it does not turn on (absolutely no indication on the controller panel). After a while (from 5 minutes to an hour), it spontaneously turns on and works without any problems. After any short-term shutdown (even for 1 minute), there is a problem with turning on again (again have to wait).
Inside the controller visually no traces. The power supply is ok. Capacitors are ok. I can't figure out what the problem is. Moreover, recently the other controller also began to show same problem (controller from a punch press of the same model and the same manufacturer).
Can anyone advise?
Thank you in advance for your help.
Sincerely,
Sergey
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
170
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi all. Simple as simple can be, I don't understand what's happening. I'm toggling he OSR on, GX_LUB_PUMP1_LEAD should switch. It doesn't. The...
27
668
