omron usb to serial
Krypton1592
Nov 2007
south carolina
has any one went online with a omron c200hs plc using a usb to serial adaptor (belkin f5u409). i can go onlin with Allen Bradly plc, HMI's, cuttler Hammer plc's. but omron is not recognized
thanks
Not a C200HS but I went on line with a Omron and a Keyspan... I would think that the Belkin would work fine.
Actually I had a customer that was unable to connect with the Belkin unit to Omron products.
This has been an active topic in this forum. It appears to be a combination of chipsets, computer, adapter and device that determine if it will work or not.
As suggested above, I would try the Keyspan unit (I use one).
It seems to be about the most reliable and consistant so far.
Hope this will help.
I was able to get that particular converter to "SORT" of work to Omron with Vista and a Vista driver I downloaded from the Belkin website.
The problem I had was that the damn thing kept losing communications and I woulkd have to reboot the laptop to get comms back for a maximum of 5 minutes before it failed again.
The Omron one is not cheap but it does work faultlessly with everything I have tried it with.
Hi all, I have a problem connecting Omron CQM1H to my laptop using USB to Serial. (my laptop come without serial port). Anyone can help me...
8,097
I have 5 packaging/label lines that use the Omron CPM2A processor that is interfacing with the following. Noax touchscreen, GSE 650 scale head...
14,042
D
I have recently recieved a new laptop from work which doesn't have a serial output. This was remedied by using a USb-serial driver. For some...
5,606
Hi, i'm using cx programmer 9.5 running on my vmware and trying to connect to my CP1H- XA. I did the required driver installation suggested in the...
2,864
We are working with an omron NB Hmi and a Cp1L PLC. These devices are monitoring and storing a temperature Log in a USB memory connected to the...
1,774
