on line modifications
Hope your good at programing, I like my widgets getting chewed up in machines.
If you could change program while running it is not recomended.
It Depends....
If you're doing machine control, then off line changes are usually easy to implement. But....if you're doing process control, it may take hours or even days to shut down the process. If you only have to make a minor change, then the down time cost far out weighs the "risk" of doing online modifications.
Since I work in the process industry, most of my changes are made while the process is running. I have a co-worker review the intended logic change, and then implement the new logic in parallel with the old logic, and have the new logic only fire a "dummy" bit. I then observe the process and my "new" logic to ensure it is functioning as expected, making any required modifications. Once every thing is working as needed, I then remove the dummy bits and move control to the new logic, and disable the old logic. I then wait a day or so, and if everything is still operating as expected, I then remove the old logic.
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
97
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
307
151
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
237
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
87
