ONLINE Changing ladder logic for a redundant PLC5
ckchew666
Aug 2003
Malaysia
591
I need advise on a redundant PLC 5. I need to modify the ladder logic and add in some new data files for a redundant PLC5/40. The system is critical & cannot afford a shutdown.
I'm planning to change the program on the secondary (backup) PLC5/40 by putting the secondary PLC 5/40 into REM, after the modification is done, I'll switch it back to RUN. Then, I'll switch the PRIMARY PLC5/40 into REM & let the SECONDARY PLC5/40 take control, while I modify the PRIMARY PLC5/40 ladder logic.
After completed, I'll switch the PRIMARY to RUN also and switch the SECONDARY PLC5/40 to PROGRAM, so that the PRIMARY PLC5/40 will take control.
I've no experience with redundant PLC5 system, am I doing the right thing in order to avoid the machine to shutdown?
Hope someone can give me a word or two. Thanks :)
Hello All I am new to the forum and also to the world of PLCs. I would like to have your expert advice, If I can change the floating point value...
5,782
I have a PLC5-40 with 1771-IL card. I need to change one of the channels from its current configuration of 0-5vdc|0-20 ma to the new required...
1,412
1,252
I am working on expanding a control system for tanks, adding two additional ones. Each tank is represented by it's own equipment phase. The...
2,853
Using studio 5000 with 1756-L71 and 1756-ENBT cards. Is it possible to change all IP Addresses that are being used for a plc, drives, enbt cards...
1,481
