Online Controllogix via Ethernet
djpalaz
Jan 2007
Montreal
57
hello All,
I'm trying to go online with a controllogix PLC via an ethernet module. I keep on getting the attached error message. I know i'm connected to the module since i'm able to ping it and I set the IP address for the module. I'm connected via a wireless hub.
What is the error message?
How are you trying to go online? What software? What configuration?
"RSlinx setup with an ethernet driver" what does this mean, how do i check this. Im using RSLogix5000. I used BOOTCP-DHCP Server to create the IP address for ethernet module.
Common Procedures
RSLogix 5000 has an "Online Path" associated with the project file that specifies which RSLinx driver, which networks, and which controllers slot number is used to communicate with the controller. There is an RSWho browse button directly adjacent to the Online Path field that allows you to "browse" to the controller.
This Path Bar is visible by default. If it is not, turn it on from the main menu by selecting View -> Toolbars and checking Path Bar.
You must have configured an Ethernet driver in RSLinx to be able to browse to your controller.
Logix5000 needs to know the correct comm path in order to find the actual equipment that is associated with the project.
As it says, use RSWho under 'communications' in RSLogix5000 to browse to the PLC Ethernet module. Once you find it it should go online. If, when you fire up RSWho there is NO Ethernet driver configured you'll have to go into RSLinx and set one up. All you need to do that is the PLC IP address and use 'configure drivers'.
Try that and see if it helps.
Since you are evidently "diving in" as a new user, I very strongly recommend getting the Logix 5000 Controllers Quick Start manual, Publication 1756-QS001.
In fact, have a look through the Rockwell Automation Integrated Architecture Recommended Literature Guide, Publication IASIMP-RM001. Get some hardcopies from your RA distributor.
open up rslinx and click on the communications tab select configure drivers click on the down arrow then select ethernet divices then click add new then o.k. then enter your ip address then add new then o.k.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
393
Are any of you guys out there aware of a consolidated list of I/O cards that can be replaced online? We just replaced a 1756-IF16 card while the...
1,540
Hi I'm trying to change the scale in a analog Input module in the module while online. I got a warning saying something like Module changes could...
2,063
Good Afternoon, I should know the answer to this . I have a 1756- 4-20 ma input card with spare inputs .I would like to add a new Analog...
1,857
Is it true that you don't get the green True/False bars in "Online" mode on every element type? For example, the GTEQ or NEQ block: it doesn't...
3,472
