op17 startup problem with $657 error.
aymen
Mar 2009
tunis
Dear all
i have op17 with ref: 6AV3 617-1JC20-0AX1
prootol softwear V6.0 SP3
i have send a configration in two op17
the first one is ok
for the second one:
after sucess for sending configuration there is two message system and the op dont go to startup view.
in facts the op look like planting in boot phase. "simatic op17 v1.04
verify loded data
start code"
and no comprehensible character appears.
system message :
1-$657 Configured PLC protocol is not possible. (appaear only after sending configuration)
2-$004 fail-No #5
#3#65535#65535.
(test RAM is OK)
so i want to unterstand if it is softwear or hardwear problem?
and why in the first one is ok?
and if there is some remedy for this situation?
thanks for siemens.
Error: $657 Cause: Configured PLC driver not supported by version of device you are using (serious error)
Remedy: Change protocol for version of device you are using and repeat download configuration
Are both units identical? or is one a different release/revision/version?
Please check both part numbers and version and post here!!
I am receiving the following error message on the Simatic OP17 $545 DB 32b 41 3 not avail. Before the restart that this HMI always does...
20
6,234
Hi. I am looking at a future project of migrating some OP17's to some newer HMIs. I have briefly looked at this & it doesn't seem as easy as I had...
2,310
Does anyone have the old ProTool software from Siemens? I was wondering if someone could open a project for me or sell me the software. From...
7,966
2,864
I want to up load progam from old OP 17 to PC and then down load to new OP17.For this I need software,Cable connection lay out and the...
1,692
