Op77a
mohamed_plc
Jan 2009
algeria
Hi all,
i want to transfer a program from winccFlexible2005 SP1 HF7 to OP77A.
i have PC/PPI cable 6ES7 901-3CB30-0XA0.
i can't transfer program to OP77A.
Witch dip switch i must use.
And what is the configuration I need to use in winccflexible to download the program.
Thank you.
HI, i am trying to transfer a programme through wincc 2008 , unfortunately it shows device is not connected. i am using usb/mpi/ppi adapter. any...
1,268
Hello everyone, I am stuck here with an OP77A HMI, the problem I am facing is that I am unable to open its loader as its startup delay(as I think)...
3,324
which keys should we press to make the op77a switch to transfer mode? it is only displaying " This device contains free software ... "
1,666
Sir, We purchased the HMI pannel OP77A. When we just tried to update the OS for version changing, the updating procedure just...
18
11,382
Hi all I'd a SCADA system with HMI OP77A, and it's required to make a State and Forced variables (I mean to write an address of my plc and get...
3,103
