OPC communication between plc and pc slow
Plc_User
Dec 2005
Belgium
317
I have an opc communication between a pc (with a common network card) and a plc S7 315 2 dp, but it is extremely slow, what point should I pay attention to to speed this up?
Thanks.
Please describe the EXACT hardware and software setup on both PC and PLC.
How much data ?
How often ?
What is "slow" ?
Plc_side : cpu 315-2dp 2AG10 v 2.6.5 ethernet card lean, cpu-cycle time = 50 ms, cpu load for communication : 50%, , pc-side : standard network card and Simatic net 2008. About 6 reals, 4 dint's, 6 bools are written within 6 seconds. These are 'separate' variables = not placed in an array. The values are written with the write synchronously method by a Delphi programm, but same delays are encountered by the OPC-scout.
To the mpi port also an TP177A is connected, to the ethernet card also a MP277 card is attached. If the MP is connected to the ethernet or the mpi does not make difference. When the MP is disconnected communication goes gast : 1-2 seconds. The panel has a lot of variables, but only few are updated continiously.
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,836
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,273
Hello there im neew in this site, somebody knows how to create OPC communication with Allen Bradley (compact logix, SLC03, and a PC? the PC will...
3,021
Hi What is mean the access path of tag ? and how i can configure the parameters for every tag? (Adress, tag name, access path) OPC Server...
1,505
Currently OPC Client (PI OPC Interface from OSISOFT) is reading the data from RSLinx Gateway which is installed on different PC. And we are...
7,054
