OPC SIMATIC.NET sync or async
Lc001
Aug 2006
istanbul
i am trying to connect to s7300, but there are two methods 1 is async and the other is sync. what is the difference ? for a continous data readin operation which one can i use? (i need to read data and write it to sql) do you guys have any .net sample project which you can share ? thanks
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,926
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,452
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,139
My company has been working with Siemens equipment mainly. I've Step 7 v5.5 installed, and TIA V13 portal installed and WinCC 7.0.3 installed...
1,686
Hi all! Is there any way to configure opc server on pc side, to communicate with s7-1200, only by entering ip's and etc in opc server software...
3,461
