Opto 22 good or bad?
creativepaper
Feb 2008
Worcester
168
We are planning on another upgrade, threfore another PLC. The choice at the present is either a AB ControlLogix platform (L61) or Opto 22.
Our IO count is
34 Analogue PID loops
Dig Input = 27
Dig OUtput 56
The advantage of the Opto 22 system is the hardware and software cost.
The advantage of the AB platform is I have used ControlLogix therefore know that it can easily and reliably handle this.
The programming will be done by a 3rd party so learning the Opto flowchart language is not needed.
I read the past threads on the Opto that people have reservations on their quality (esp the IO) and the lack of online editing.
The required loop update rate would be between 100-500 ms (usually closer to the 500ms mark).
The Operator interface will be on PC's.
[snip]
Amortize the cost over the expected lifetime of the system, and I'd imagine you aren't looking at very much in either case.
Then consider ease of expansion, and HMI communications (to whatever, SCADA, PanelView, CutlerHammer, Red-Lion, whatever).
I'd go with the Logix myself.
Hi, Does anybody know if it is possible to run Yaskawa's DriveWizard software on a PC, to monitor and configure V1000 VFDs that are connected to...
2,072
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,713
I'm having trouble finding an OPC Server besides the OptoOPCserver that will communicate with the LCM4 controller. I know the LCM4 is an obsolete...
1,851
Hi, Has anybody controlled and monitored a PowerFlex 525 VFD using Opto 22's PAC Control? The client is still undecided between EPIC or staying...
2,503
Hello every one!!! (1) I got problem in connection of encoder 12 v and delta plc EX ... How can i connect encoder with delta plc beacuse delta plc...
1,401
