Opto-22 Optomux driver for Allen-Bradley
killer
May 2008
York Haven, PA
106
Does anyone have an ASCii driver written to access Opto-22 I/O system over RS-485 using an Allen-Bradley PLC / SLC / Logix controller?
No, but good luck with that.
We looked into it a couple of years ago (eight B2 racks connected by RS-422 serial), entertained the idea you have, then decided to purchase newer gear.
The regional AB sales guy that came out was unable to offer us a viable solution, so we went with some Sixnet RemoteTrak I/O and an iPM controller/gateway.
Opto22 offers E1/E2 brain boards for a reasonable price, which come with a serial pass-through feature, but you have to address the brainboards using TCP-Optomux. To make this, you need to run a standard Opto22 serial driver, with a UDP comm port redirector program running on top of it to put it on the LAN.
See our sister company produces dirt-cheap but good I/O boards that they designed to talk with Optomux protocol. I'd really like to use them with a PLC for cost savings, but the protocol is proving to be the stumbling block.
The search continues.
Look at the product suite from Western Reserve Controls (wrcakron.com). They make some Optomux-compatible gear that includes a 1746-BAS driver.
The optomux protocol is documented here:
http://www.opto22.com/site/documents/drilldown.aspx?aid=1941
It looks like rolling your own could get pretty hairy depending on what functionality you are looking for, but at least the protocol is documented well enough that you should be able to pull it off at the expense of your time.
B&B Electronics offers custom developed solutions for problems like yours according to this link:
http://www.bb-elec.com/tech_articles/converters_industrial_bus.asp
And finally, a thread from optoforums that pertains, but doesn't really offer any solutions:
http://www.opto22.com/forums/forums/675/ShowPost.aspx
In all my searching I didn't come up with too much...
Hi, Does anybody know if it is possible to run Yaskawa's DriveWizard software on a PC, to monitor and configure V1000 VFDs that are connected to...
2,055
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,703
I'm having trouble finding an OPC Server besides the OptoOPCserver that will communicate with the LCM4 controller. I know the LCM4 is an obsolete...
1,845
Hi, Has anybody controlled and monitored a PowerFlex 525 VFD using Opto 22's PAC Control? The client is still undecided between EPIC or staying...
2,492
Hello every one!!! (1) I got problem in connection of encoder 12 v and delta plc EX ... How can i connect encoder with delta plc beacuse delta plc...
1,393
