Opto-Isolation
stephen
Apr 2004
Hi once again.
An Engineer at work has given me a brief explanation regarding this but he wasn't so sure. He said "it is a barrier with a LED in it"
Is this correct?
If not could you Shed Some light on the matter?
thanks
Steve
What exactly is an opto-isolator
Hello,
An optical isolator is an LED driven transistor. The LED is powered and shines on a photovoltaic cell of some sort, this photovoltaic applies a voltage to the base of a transistor. This charge then biases the transistor as required and allows current to flow to some degree on the other side. In this manner, one portion of a circuit can cause changes in the current of another part of the circuit with no direct electrical contact. This is used primarily to isolate one portion of circuitry so that current/voltage spikes in that one portion (say a large DC motor drive circuit) will not effect any other portions of the circuit; i.e. noise sensitive components which control them (PLC's, Microcontrollers, etc.). The entire purpose of isolation is to seperate the portions electrically so that noise in one node does not effect any other nodes adversely. Note though that when using opto's or any other form of isolation (relays, etc.) you can get different ground planes, and there can be a greater voltage difference between different portions of a circuit than expected (12 volts to ground on one side of the isolator may be more or less than 12 volts with respect to another side's ground);this is easily checked with a voltmeter if needed, and is essential when trouble shooting various problems (I personally burned out two $200 fiber optic amplifiers because of a ground plane difference I was unaware of).
Hope that helps,
Scott
I am currently doing an electronics assignment on PLCs and I have a question to complete as follows: With regards to different types of INPUT and...
7,372
Hi, Does anybody know if it is possible to run Yaskawa's DriveWizard software on a PC, to monitor and configure V1000 VFDs that are connected to...
2,056
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,703
I'm having trouble finding an OPC Server besides the OptoOPCserver that will communicate with the LCM4 controller. I know the LCM4 is an obsolete...
1,845
Hi, Has anybody controlled and monitored a PowerFlex 525 VFD using Opto 22's PAC Control? The client is still undecided between EPIC or staying...
2,497
