OT....24 VAC transformer
OK I appreciate all of the input. It makes slightly more sense to me to ground the secondary to chassis ground instead of tying it to the 120 VAC neutral. But really I don't see how it makes any real tangible difference one way or the other since the 120 VAC neutral is tied to ground at the supply.
And yes the 120 VAC with neutral is coming into the box from the nearest breaker panel.
i ground x2 of the secondary to the pane backplane.
WHY ?
i did an installation and there was a 75 volt ac floating ground, no joke!
from the neutral side of any plant receptacle to the ground measured 75 volts ac, tested on 3 different volt meters. we notified the plant engineer immediately. the electrical contractor that installed the main plant transformer failed to ground something ( can't remember).
every time we tried to drill a hole with an electric drill, you got shocked. we grounded the x2 terminal and the problem was solved. NOW it is a requirement on all equipment.
james
hope this isn't out of line, but only forum I belong to where I might get the answers I'm looking for. My company bought a pleater from a company...
4,504
We have 480vac 3 phase in our shop but our sales engineer just sold a machine going to Canada that requires 575vac. Problem is it has a 150 HP...
6,724
Hello anyone, i need your helping. coz im building switchboard send to USA with UL label. i could find all component with UL listed but...
3,711
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
136
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
367
