OT: 9 pin D-type connector
Gummit
Jun 2007
Hertfordshire
25
A question for the UK guys on here.
Does anyone know of a 9 pin D-type serial connector that comes pre-wired at the connector end and then has say a couple of feet of cable and then is left unterminated.
I know that I can buy a cable that is pre-wired at both ends and cut off one end but I suspect the internal wires would be pretty fine and fragile.
Oh, and before anyone suggests I just make my own, I want it to be moulded if possible.
Cheers
Gummit
Cheers
Gummit
And how would you like it wired sir ?
Seriously though you need to really tell us how you want the plug end wired first, is it RS232 PC to PLC, RS485, Null modem etc. etc. ?
RS sell heaps of cheap cables which you could just shop the end off, i cant see any to free ends though.
I usually just by a an extension cable with the desired connectors moulded on and cut one end off. I have found the wires to be small but not unworkable.
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
261
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
381
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,070
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,538
In my FC I use an inout variable for the memory of a Set/reset. When i call the FC i have the pin at the entry side of the block while i would...
1,967
