allscott
- Join Date
- Jul 2004
- Posts
- 1,332
I recently inherited a 250HP ABB DCS400 drive. We hooked it up to a machine that was transfered from a sister plant and started it up last week connected to a 150HP straight shunt DC motor.
I wasn't involved in the initial set up but our senior electrician (who I have confidence in) started it up without tuning it. The machine doesn't require precise speed or torque control at all so I didn't question it.
The electrician who set it up is off work and I was called down to look at it last week because it was overshooting badly (200 RPM, while ramping up to 1750RPM). I decided to run through the autotunes in hopes getting better control.
I diconected the load and did a field tune, and armature tune, and a speed loop tune. I reconnected the load to the machine and it went completely stupid. Trying to ramp up to full speed almost instantly, running backwards even though the command reference is always positive. I ended up settting it back to factory defualts and setting it up again without auto tuning.
The machine is running again over the weekend with highly exagerated ramps and EMF feedback because I thought maybe there was an issue with the tach.
Any ideas what went wrong?
