Ot:ac motor slip ring
osmanmom
Mar 2014
JOHOR
1,457
i don't know much about ac motor slip ring.
i have small ac motor slip ring about 2 or 3 hp its possible to me to use VFD,
any idea or wiring example,
thank-you in advance
Slip rings when connected to a variable resister bank, it allows you to vary the motor starting speed, because of the load characteristics [heavy load]. Doing so reduces the startup current, so when it start to roll, you reduce the resistance gradually and eventually you short the slip rings when it attains its nominal speed.
Osman, you didn't mentioned what is the need for change. As the link from previous post, it is better to change to a VFD rated motor if you are looking for a variable speed options.
Regards
thanks for the feedback,
i just finished the task after found the wiring diagram.(stone age machine)
the system not using resistor.
One of our factories needs to start an old slip ring motor. I suggested that they use a common "resistor selector" system to start the motor then...
1,898
Anyone ever worked with ABB ASTAT or ABB MoCon drives? Thanks!
1,476
Hi, I have used Vfds for Squirrel cage induction motors. I am now required to use a Vfd with a Slip ring motor. My question is, what do I do to...
2,958
Hi We are looking at a 100Hp 12 pole 490 rpm Slip Ring motor on a rubber mill. The existing system is a resistance reversing starter from about...
24
8,837
I am interested in measuring actual motor power. I think that motor slip is directly proportional to torque, and given torque and rpm hp is...
3,523
