BudW
I am looking for some opinions on TSSA inspection.
I am working on some assembly equipment that will be going in to Canada. This equipment will be supplied by the plant air supply. The airdrop is ½”. The 1/2'” air drop then drops into a ¾” pipe used as a drip leg (with a ball valve at the bottom to drain any water). Do you think that this is now considered a pressure vessel of ¾” or greater and will require TSSA inspection?
Bud
Bud
