OT: chicken coop automation
dploof23
Jan 2010
Massachusetts
505
Hello,
I was just wondering if anyone has ever automated a home chicken coop, and if so you may want to share some ideas and details.
I was thinking, (so far):
Automatically open and close the coop door with a photocell based on sunlight.
Automatically turn on and off the heat lamp and water de-icer based on temperature.
Automatically fill the water with a solenoid valve fitted to a rain barrel.
Critter alarm based on movement at night.
This is just a start and I would welcome any ideas or suggestions.
Thanks,
Dave
One big problem in a chicken coop is when the chickens gang up on a weak or injured chick and peck it to death. Perhaps an anti-pecking alarm could be designed using an infrared detector that is calibrated to detect a pile of chickens and then set off a loud horn or spray of water to disburse the culprits.
On the poultry farm where I worked once, every new batch of young chickens got debeaked to prevent the pecking syndrome. We used a debeaker that had a heated schssor blade that melted through the beaks. I hated the smell connected to that job of burning off the beak while holding the flopping chicken.
I too worked as a de-beaker when a youngster. If you have ever burned a piece of fingernail, you will know what it smells like. BAD! But that wasn't the worse job I had.
You may want a time delay on the door closer so you don't lock out any straglers. Maybe an auger fed food dispenser would be a nice touch.
We don't have any problems with the chickens going after each other. We have roughly 20 birds, all hens, and the majority of them are silkies.
I like the idea of the auger feeder. I have to look into what I have for parts available.
Thanks for the ideas!
Dave
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
74
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
103
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
247
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
142
