OT - Disconnect handle Selection Help
Tim Ganz
Dec 2010
Dallas, Texas
692
I am tring to select a cable operated handle for a 140 U molded case breaker that will be used for a main panel disconnect.
The link below is where I am looking at.
http://www.ab.com/en/epub/catalogs/12768/229240/229254/305540/3087073/tab2.html
Looks like I have a choice between non metallic,stainless steel and Painted metal.
I would like to get some direction / help with making a choice. What are the pro's and con's of each one?
What is commonly used?
I have only a little personal experience with that style from A/B, but I found their hardware to be better than CH or Square D.
Here, I use stainless only, the others rot away in a few months...(heavy washdown in most areas).
I haven't used the "non-metallic" but the last one I bought was for a 400A disconnect switch which takes too much force to move for me to use a plastic operator.
Be careful with cable length, it is easier than you might think to end up with one that is too long or too short to fit well.
I can't find these disconnects I know we have used them before but I didn't spec them so I don't remember what they where. I am looking for an...
2,614
323
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
357
Good afternoon PLCS.net! I have a very odd situation that is happening, and hoping someone has some insight. We have just laid out a new 10G...
667
This question is about a Q68TD-G-H01. When I disconnect the thermocouple connected to channel 8 of the module, I am expecting D111.F to go TRUE...
3,488
