OT: Fire alarm
theripley
Jul 2008
laguna
545
Hi.
I know this is a big OT, but I just need to ask. I have a Brand A fire alarm control panel that requires new detectors. However, Brand A is not easily available on my location so I would like to use Brand B detectors to be connected to the Brand A fire alarm panel.
Question:
Is there anything that I need to consider to successfully connect the detector to the control panel? Please advise.
a standard smoke or heat detector that just closes to alarm would be interchangeable from that standpoint but operation should be tested afterwards. an addressable system is not interchangeable but they are also newer.
Please state the variables consider
Are the detectors addressable?
If so, do both systems use the same addressing?
Is Brand A a 2 wire detector?
It is OK to tell the brand, and it would be good to provide spec sheets for both detectors. Maybe someone here with more experience could tell you more about it.
I have not worked on any Fire Alarms for several years, but ours used to all be addressable, and we had to have our supplier pre-program them, and then could install them.
Hi guys I'm working on this project: There's a Fire Alarm system installed in a plant that we want to communicate with using a CompactLogix L32E...
2,493
Dear, I have a room which is being served by FM200 panel and fire alarm panel is used for monitoring, in case of smoke detection, FM200 panel...
2,908
Hello everybody a client asked us to design a fire alarm system for his factory using s7-300. what I know that there is specific CPUs for that...
3,175
Dear, i want to control a variable frequency drive from a fire alarm panel for some extraction, is a output analog is available for fire alarm...
2,529
Anybody has EST3 (GE fire alarm PLC type) configuration software and cables. Willing to pay for it. Stuck with some dude that did not finish the...
7,384
