I understand that you have a single conduit with all cables in that conduit.
All VFD manufacturers recommend that the motor is shielded correctly.
Your supplier will be well aware of this. I would say they are trying to pull the wool over your eyes.
you need to either shield the control or the motor wiring.
Even install a second conduit.
Earthing the conduit is not a shield nor should it be.
the Relay is an Idea, as you need speed only use the Coil - not the contacts.
