OT Hard Disks
Now you can lose an entire organisation's worth of data on your desk somewhere.
Hell, you can lose it in your pocket and accidentally put it through the washing machine!
Although having said that, many years ago I had (huge at the time) 256MB USB stick which went through the wash and continued to work admirably until I lost it several years later. So maybe your organisation's data will be fine!
HHmm,
When I did my final year project at Uni (1983) on fault levels in the National Grid, my programming was done on an HP machine with an cassette tape drive.
in the late 80s, I was programming GEM80 PLCs with both the black "portable" terminal and the less portable Yellow Peril. I usually had to put these in the car to take them between sites.
In my previous employ, we thought it was great getting a £5000 HP Vectra 386 "state of the art" around 1990.
I also found out recently that our last PLC5 Co-processor card had a spare in our stores that was actually no use to us, as the original had been "upgraded" by replacing the motorola chips with some that had a greater memory (probable still in kb though).
Yes, I have a recently purchased 2TB portable hard drive that struggles to load up and be read by some of the PCs in here, whereas the older USB sticks work very well.
Hi - I'm a newbie to the PLC world but was recently asked if we could store more than the 2G that the CompactLogix 5370 allows by its max size SD...
1,321
Any help appreciated, Proposed question: I need to track parts to count the rejects in a rotating machine but having no luck tracking proper...
2,339
I've been beating my head against this problem intermittently for a while now. :banghead: We have 3 meter with hard mechanical counters on the...
26
7,895
Outside what used to be an RCA TV plant. Shame of a use of a good robot.
1,689
Really interesting analysis on if, why and when Soft PLCs are going to replace standard Hard PLCs in the industry...
25
6,597
