OT: Harsh environment electric motor paint
steveb1475
Oct 2005
Utah
111
Hey all,
I was wondering if anyone has any suggestions for an electric motor paint that will stand up to acid/caustic washdown without creating any thermal insulating effects.
Thanks,
Steve
Well, Idon't know that any paint will have too much insulating effect unless you really slather it on, or that any one kind will be worse than any other.
I'd suggest looking at epoxy paint for corrosion resistance. You might also talk to your paint vendor for suggestions. Finally, Baldor and other have hazardous duty motors that are more corrosion resistant than standard ones.
Steve,
Take a look at Sherwin Williams Polane. Bulletproof paint - its a two part poly and cures very hard, but you need a paint booth and special equipment. If you are in the SLC area try Global Coatings in Pleasant Grove, they can shoot it for you.
Specifying a Mill and Chem Duty motor would probably have avoided these problems. They typically have a stainless steel shaft and better paint ( I believe it is epoxy in most cases).
OP:
I just use sherwin williams cold galvanizing spray paint. Once the painted or baked enamel coating starts shipping it has been my experience its going to continue to do so under whatever paint you have. Not to mention, in a corrosive wash down environment like my plant the motor is likely rusted where the paint chipped off and would require a good bit of prep work to get paint to stick well. I just have a maintenance guy go around and put on a fresh coat about once a month which takes 1 guy about an hour. Yes its a quick fix but the costs of a long term solution outweighs the inconvenience of occasionally running around with a can of spray paint.
In response to DickDV, I would have to agree. If you are in a washdown environment I would be specifying leeson stainless steel washdown TEFC motors. They are more expensive but the price to pay is small to keep USDA happy.
Any recommendations? The environment ranges from frozen and damp during production to hot and steamy during high pressure washdown, with some...
7,539
Greetings everyone. I have an application which requires an HMI in a harsh environment. Normally I don't put HMI's in harsh environments, but I...
4,977
Hello, I am looking for sensors to measure the roll diameter of a roll with unwinding steelwire. The max diameter is aproximately 1500mm and the...
5,479
Hello I have a friend who is building a street rod. He has seen me use plcs to control things in a small haunted house for Halloween and also a...
5,865
D
It is not critical. But would be nice to add a stepper motor to the hp rinse arch on the car wash to change the rinse angle based off of the...
3,489
