steveb1475
OP
Dan,
Based on the linked info I don't think its an open tank, it appears to be a heat exchanger where ice forms on the tubes but doesn't freeze solid. Process water flows through it so it can't be allowed to freeze solid. Maybe Steve can elaborate.
Yes, this is how it works. Ice builds up until a single point thickness probe is made. A contact from the probe would close the ammonia vapor regulator to stop production of ice.
BTW Steve, just out of curiosity, is the absorption/distillation driven by a burner, electric element, or does the process recover heat to drive it? Just curious because I think that there is a future for absorption chillers as we go green.
This isn't an absorption chiller, it is a basic ammonia vapor compression system.
mellis said:DeltaT is going to relate to the load on the ice bank. How fast it is being depleted, not how much is left.
To use the electrical analogy, the OP is asking how much charge is left in the battery. Not how fast is it discharging.
Exactly.
leitmotif said:Assuming you know the initial level of charge then the total Ah taken out will give you remaining Ah thus time at this rate. IF you are in doubt you crawled in the battery well with a hydrometer and measured the pilot cells.
The problem is that I never know the initial level of "charge", just seems a lot easier to find a sensor than to try to calculate ice production and usage.
