OT: Label Dispenser
croakus
May 2004
Dayton, OH
101
All,
Has anybody seen/used an off-the-shelf automated tape or label dispenser? I'm looking at an application to dispense felt pads for production that are around 20mm x 60mm, 1mm thick.
I'd rather go off-the-shelf vs. McGuivering eight of them.
Thanks in advance,
Mike
(Not sure on the spelling of "McGuiver" - the patron saint of maintenance and manufacturing 'engineers')
Lot of questions
Are the felt pads on a roll? or you need a single "item" dispenser..ie the pads will need to be stack and dispensed as needed? Will they be applied to another object? Adhesive backed?
More info please.
Sorry about the vague question.
Ron,
The felt will be adhesive backed and on a roll approx. 12" dia. There is no real 'stiffness' to a piece, so I'm looking for a photoeye to stop/detect felt piece as it sags off the edge. It will also need a backing paper takeup.
The felt will be hand applied to the production part - no need for automatic application.
Hope this paints a better picture.
Mike
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
420
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
146
Hello, My company has recently been tasked with a redesign of an HMI and they were originally using Numeric Inputs to display the values. I am...
974
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
Hi there! I'm new to GX Works3 so please bear with me. So far I've created a new project with an FX5U PLC and tried to add some global labels...
1,188
