OT: Masonelian + Siemens Sipart PS2
silva.foxx
Dec 2004
North Wales; always West to England!
519
Hey up
Just curious... we have a Masonelian CamFlex II steam valve with a Siemens Sipart PS2 valve positioner. The CamFlex works as a cylinder acuating a lever to turn the rotary valve.
The positioner is set-up in a Linear Actuator configuration as opposed to a part-turn. The positional feedback is direct from the valve spindle as opposed to a lever.
Has anyone any experience of this set-up that can share info on, please?
Regards - s.f
silva.foxx said:
Hey up
Regards - s.f
what sort of info are you after? we have some of these valves on site, i dont have much experience setiing them up but i could probably dig out the manuals and scan parts if you need.
cheers
myles
Wondering why it would be set up as linear when it's a rotary valve and the positioner monitors the spindle angle. OK you can say the actuating cylinder is linear but that moves a lever to turn the valve as opposed to a cylinder that lifts a valve.
here is an extract from the manual, it states that the valve has a modified linear flow characteristic, hope that helps some.
cheers
myles
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
167
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
83
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
172
203
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
112
