OT - Miniature DC Motor drive
Jim G.
Nov 2007
Georgia
187
Not necessarily a PLC question but could eventually turn in to one. I have an Automation Direct GSD1-48-10C dc drive set up driving 2 small 1/25 hp motors. The drive is set up for 24 VDC input and 24VDC out. The motors are rated for 12 VDC. I have the speed pot mechanically limited to only put out 12 volts to these motors. Seems to be working. This was a down and dirty response to a production request.
I only have 24 vdc available as a source in my panel, but would like to find a drive that only has a 12 vdc output. Can't seem to find one. Any recommendations? Needs to be able to fit inside a 10 inch by 10 inch enclosure.
The PLC part will come into play when trying to start and stop with the production line. Not concerned about that at the moment.
Thank you for your input.
Hi all, Does anyone know of any really small(Like 3in X 5 in) Display boards that can connect to Contrologix PLCs? A gateway to the device...
1,686
I had trouble for a week trying to get a Marathon Symax Motor autotuned to work with a Powerflex 753 drive. I solved the problem and thought I...
62
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
318
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
252
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
354
