OT: MODBUS rtu 485 T connectors
barryoc
Nov 2009
Kilkenny
148
Hi everyone,
I will be working on a project shortly that will be using a Modbus rs485 network. I am trying to source a t-connector of some sort for the drop-lines from the BUS line. The drop-line side only needs to be a "quick" connect type (no tools required) as operators will be required to change sensors. The other issue is that this network will be outdoors so the connectors need to be waterproof. The network will run in a Belden cable for Modbus 485 and 24v DC power. I was thinking of something like an M12 y connector in a waterproof junction box with a hole drilled for the dropline but it would be quite crude. Y Connector
Has anyone ever come across something like this?
Regards,
Barry.
Thanks guys,
Im now searching google for a small junction box, gland in either side and use a waterproof bulkhead connector at the bottom for the drop-lines. This should be a lot better than a splitter.
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
233
I am trying to figure out some communication specifics for a Modbus RTU network that I will be integrating with and could use some help to make...
2,111
I'm getting no response from a device I'm trying to communicate to with a Beckhoff IPC. I'm not sure why it's not working. Attached are pictures...
642
Been trying for a while to get a flowmeter with Modbus RS485 comms to talk to my Redlion Graphite HMI. Cable has been checked 3 times all good...
875
HI guys: I am attaching several diagram from several sources, it seems to be that there is no such a wiring standard for modbus RS485 RTU. In some...
24
4,580
