Okay, so five days since the project began, I am on budget for money, but behind schedule due to a somewhat of a surprise 3rd shift stint to upgrade a compressor control package and scada...
So, after pulling a double shift with 6 hours off in between, I still don't have a wall. I slept 8 hours and got up and felt okay, but too brain dead to try to fab a wall, and decided I could still use a shovel in this state, so I dug a footing. Then, only two hours after being awake, I took a bath, fell asleep in the tub, so I drained it and took another hot bath...not that I was sore from turning a shovel all day or anything
I just mainly wanted to see how bad the water was. It smelled fine, but just had a fine silt up to a few grains of sand. About a tablespoon of dirt after ~30 gallons.
Then I stretched out on the floor in the living room and relaxed my legs and feet while I assembled all the connectors, applied teflon where applicable, and then I slept another 8 hours and woke up mostly turned around back to day shift.
Work was pretty busy, but I am all mopped up except for two loose ends on this weeks projects.
So today, I am glad I didn't start a wall on top of dirt, and try to sneak in a footing later.
I never can guess how much quikrete to buy, and as expected, I will be picking up three more bags tomorrow.
Two more days 'til a wall can begin, at which time I can attach my strainer/filter.
It will be built on two pretty good sized footings in the pic.
The depth is deceiving it is about 27" down to the top of the pipe , and the footings are about 18" square and 3' tall.
Thanks for all the added info...flow based recharge potassium compatible softener sounds like great advice.
My torque arrestor is spread out so that it was difficult to push the well back into the casing, but it slid down smooth and no snags, so I suspect my casing integrity is good. I pressure tested the from the well with 80PSI air and found no leaks when I had it out.
My soil is red sand in this whole section of Oklahoma. I am not sure how far down I should expect bedrock. I live at the bottom of a ridge next to a gulley. There is a spring fed lake about "two city blocks" away, and it's surface level rarely changes, and I would guess it's about 30' below the surface of my yard...hard to tell with a tall hill between me and it.
Keep em coming but I may not be able to reply with any progress for a few more days.
Paul
