OT - Striped MTW vendor
MikeW
Feb 2004
WI
265
I'm going to have a panel wired in the near future and was going to follow NFPA 79 wire color coding guidelines. Up until this time we have used informal company rules as this equipment is typically for in house use only. Our department has been expanded and we are now going to start furnishing equipment for other locations within the company. I can find lots of Machine Tool Wire vendors providing solid color wire types but have not had any luck find a source for striped wire, e.g. White w/ Blue or Orange Stripes.
Who is a possible vendor here in the states that you have used in the past?
http://www.colewire.com
If you want to do a search use hook up wire or striped MTW. I had to do this when I was in TN to locate a place that would cut to length and stripe.
I have more but cant locate at this time. Check back. I have had to use several sources, will try to find them all.
I remembered, it was Omni Cable http://www.omnicable.com/SpecPage.asp?ngroupid=155
All, Is there any reason to not use tffn wire (also marked as mtw) inside a panel? We typically use 16awg for our panels. I think the THHN/THWN...
5,504
Hi Guys. Apologies for the long winded script but I want to give you the full script I imagine some of you guys have been in the same situation...
2,248
EDIT: Just realized I left the word "FINGERPRINT" out of the title. Sorry. Can't change it. I've been requested to implement fingerprint...
3,450
Hello, I am looking for a stocking vendor of linear motors. Who do you suggest for best on-the-shelf selection? Thanks Joe
2,438
It's time to dream... Q1 If you had a new project and could choose any plc/io/motion/hmi/drive vendor, how would you decide what to use? Q2 and...
3,629
