OT: Well Water media filter material
RonJohn
Jul 2013
NE Ohio
535
I'm calling upon all of the well water treatment folks out there for some help as this is an area not currently in my knowledgebase. I searched for well water treatment forums that handled such questions but came up empty.
Our plant has a bank of media filters to pre-filter our incoming well water prior to softening. The current material has served us well over the years but filters need re-bedding. Our supplier tells us that they cannot get that same material any longer (apparently someone bought it all up for themselves) without paying a king's ransom. I'm looking for other materials we should check out as a suitable alternative.
Currently, each filter handles anywhere from 15-35 gpm with 60-70 psi incoming supply pressure. Incoming well water has hardness from 10-24 grains & trace-1ppm iron.
If any other info is needed, I'll do my best to provide it. Thanks in advance for your help!
105
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
706
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
778
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
2,019
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,300
