outputting data to an alarm banner
bherlihy
Jun 2009
dublin
hi all,
first thanks to all who have been helping me here with my code thus far,:geek:
what im wondering is is possiable to output data to an alarm banner?
what i have is 2 alarm banners one for the count is 5 or more over a value and one if the count is 5 or more under the value.
i have this coded using CPT and GEQ/LEQ what im wondering is is it possiable that if it is lats say 7 under can i display in the alarm banner error 7 under count or 7 over count if it was over by 7.
im running a PLC5 connected to a VP1000c via RIO using discrete addressing
Alarm banner setup - In the "Alarm Messages", right click [at the location you want to add the data] and select "Embedded Variable" -> "Variable" and choose the variable tag in the numeric tag selection dialogue box.
Best Regards
____________
Some background: We have two assembly machines in house that make a part that gets crimped by deforming the top of a cylinder. We use a LVDT...
20
3,981
Hi All, I have a lifting/hoist application that I am using a powerflex 755 1hp drive. I am using a 1/3hp SEW gear motor that is rated at 0.57A...
5,013
Greetings Gentlemen, I must admit I haven't worked much with analog output modules outside of controlling a VFD (and that was not in Omron) so...
2,559
Hope someone has experience with this. We've recently upgraded a system at a remote site. This is a AB SLC 5/05 processor with two 10-slot...
20
7,925
[RSLogix 500] [Micrologix 1000] Here is an odd problem I've come across. An output that turns a hydraulic solenoid on (which in turn makes a...
2,177
