Overload protection on a DC motor
controlled
Nov 2005
bowmanville
419
I have a small paper winder that is driven my a WER DC drive feeding a 250 Vdc motor. This is a fairly old machine that is not certified (CSA, UL, MET).
It is a law in Ontario that every piece of equipment be certified before it is put in service.
I had a field inspector look the machine over, and he stated it needs a contactor and overload installed between the drive and the motor. I am fine with the 2 pole contactor, but I'm not sure about the overload. Should it monitor both the armature positive lead and negative, or just the positive.
Any suggestions would be appreciated.
Generally one is enough. I prefer 2 myself due to the posibility of one side grounding out prior to the brushes.
Or if your motor has feild windings and is not a permant magnet style I would definatly use 2.
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,719
A drive was upgraded about a year ago and we just had a motor failure - apperently due to motor overloading. The 1750 HP GE motor has the...
8,437
Does a vfd protect itself from line side overload ? I know it has built-in overload and short circuit protection for load side. I also know...
19
6,112
Hi guys i have some PF4 VFDs out of service at the same time, maybe it is the problem of incoming 480 VAC, there is a MOL before VFD, I know MOL...
2,933
I think that ones acts like-> Current of supply of motor flows through bimetal bus of thermal relay. When value of current has reached I-overload...
6,918
