Pacific Scientific SC750 servo drive software
gilbertgloob
Sep 2011
Central NY
Hello,
I was donated a working Pacific Scientific SC750 servo drive and servo motor from my workplace. I am in the process of modifying my hobby cnc spindle from a router motor, to a servo motor. I have searched the internet, and cant find anything software related for this drive. Can anyone help me?
Thanks for your time!
Thanks for the reply! Wow...that is some pricey software for its age. Unfortunately, it's out of my price range as a hobbyist. Thank you very much for taking the time to help me.
The above linked page didn't have the right software, but I was able to obtain Motion Dialogue by emailing Kollmorgen directly. The executable will not run on a 64-bit architecture, so it is necessary to obtain a DOS emulator such as DOSBox. In DOSBox, you need to edit the .conf file so that the com ports are actually enabled. You will also need to go into the advanced settings for your computer's COM ports to re-assign your USB to RS232 connection to the same port that Motion Dialogue is listening to. Once all of these things were done, I was able to activate the SC750.
Forum won't let me edit my previous post, so whatever. Here's a somewhat more verbose explanation, for posterity.
I encountered this post while researching a similar problem to OP. I think I've found a solution, and documented it below:
The above linked page didn't have the right software, but I was able to obtain Motion Dialogue by emailing Kollmorgen directly and asking nicely. For the love of god don't buy a sketchy CD-ROM from the internet. The executable file will not run on a 64-bit architecture. In fact, a modern computer will quite strongly believe that the binary file that is Motion Dialogue is actually a virus, since it's a 20 year old binary file in a format that a modern computer won't recognize. In fact, both my computer and the Kollmorgen rep's computers actively tried to sabotage emailing and opening it. In order to run the file, I had to obtain a DOS emulator such as DOSBox (freeware). In DOSBox, you need to edit the .conf file so that the com ports are actually enabled. By default, the COM ports are dummies and don't actually talk to anything. You will also need to go into the advanced settings for your computer's COM ports to re-assign your USB to RS232 connection to the same port that Motion Dialogue is listening to. Once all of these things were done, I was able to activate the SC750.
I hope this ends up being helpful to some other poor fool who ends up with a similar legacy project.
Does anyone know where I can find software for programming these servo drives ? I think it's called motion dialogue. Also cable pinout would help...
2,256
Hello, PLCTalk Community ! My Google-fu is weak today and I hope I can get a better community answer. I was asked to look at a retrofit job with...
2,378
does any one know of a win 7 compatible software that will work with a pacific scientific 950 series drive? yes i'm very aware they are...
1,995
Shot in the dark but figured someone here may know. Is there a stocking Omron Automation Distributor in the Pacific Northwest? Specifically...
124
I'm in the market not only for a good, dependable torque driver, I also will need to have it calibrated from time to time. For timely turn around...
1,259
