Panasonic FP0 C16 PLC programme retrieve
jack84
May 2010
sydney
Hi guys,
i am trying to refurbish one old automated filling machine. during this process i came across Panasonic FP0C16 PLC. i never had experience with panasonic PLC.
i want to retrieve Programme from Panasonic PLC. i am using FPWin Pro 6 software for PLC. when i try to connect my laptop with PLC using RS232 cable; it shows me PLC status. But I am unable to see programme.
can anyone help me with correct procedure to retrieve original programme from FP0C16 PLC.o_O
I've used FPWin Pro quite a bit but have never needed to upload a program. That said, this would be my guess as to the proper procedure:
1. Create an empty project for the correct PLC model.
2. Online menu > Online Mode
3. Online menu > Upload Program Code and PLC Configuration
If you are able to go Online but the Upload option is grayed out, it's possible that the program was configured to disallow uploading.
Good Morning, I am converting a program from an old Panasonic NAIS FP0. Please see the attached section of logic. Step 637 when the program...
1,722
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and...
3,166
Hello. I have a machine with FP0-C32CT installed with GT30 HMI. The PLC started blinking red LED and then HMI showed PLC fail as soon as it is...
1,645
hai. .this plc have a build in battery right?is there any ways to change the battery if the battery power is low?
1,443
Hello I am new to the PLC programming, but I am trying to learn. Good for me is to learn also on existing examples, created by experienced...
2,818
