Panasonic FP0, code uploaded to PC contains errors
Richardfell
Feb 2016
Bratislava
Hello
I am new to the PLC programming, but I am trying to learn.
Good for me is to learn also on existing examples, created by experienced programmers. I have one machine that is controlled with Panasonic FP0 PLC.
I downloaded demo versions of FPWIN GR and FPWIN pro 7, to try to upload the program and to understand it. But the problem is that, when I want to upload program to PC via FPWIN pro 7, I get only the Instruction List version of program including errors, with no possibility to see it in Ladder logic.
And when I tried to download program via FPWIN GR, I have got the Ladder logic and instruction list of program, but in Ladder logic was errors (Impossible to draw). You can see the details in attached pictures.
Any help will be appreciated.
Thank you very much
Was the original program written in ladder or structured text (ST)?
Sometimes it just will not display in ladder unless written only in ladder.
If you are not seeing errors on the PLC then the program was probably written in ST.
Hope this helps,
Hello
Thank you for your suggestion. You ensured me, that it was not error during uploading to PC. I need to simply learn to understand IL instructions.
Anyway, many thanks for posting your website to your reply.
It contains many informations that beginer like me needs.
Bye
Good Morning, I am converting a program from an old Panasonic NAIS FP0. Please see the attached section of logic. Step 637 when the program...
1,712
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and...
3,161
Hello. I have a machine with FP0-C32CT installed with GT30 HMI. The PLC started blinking red LED and then HMI showed PLC fail as soon as it is...
1,644
hai. .this plc have a build in battery right?is there any ways to change the battery if the battery power is low?
1,440
Anyone have experience with either Panasonic FP0 and Delta DOP-B? I am trying to connect the two together, according to the Delta website, it is...
1,954
