Panasonic FP0 and Delta DOP-B
wen7
Jul 2014
Toronto
It is not. I thought its weird too, but Delta Dop-B only have three wires for their RS-232, Pin 2, Pin 3, and Pin 7
The wiring diagram looks like it wasn't formatted properly and is missing some connections. You definitely need a ground. For RS-232, a minimum of three connections.
You should check out the 5 pin DIN connector - there's got to be a signal ground in there somewhere or it wouldn't work
Good Morning, I am converting a program from an old Panasonic NAIS FP0. Please see the attached section of logic. Step 637 when the program...
1,729
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and...
3,176
Hello. I have a machine with FP0-C32CT installed with GT30 HMI. The PLC started blinking red LED and then HMI showed PLC fail as soon as it is...
1,645
hai. .this plc have a build in battery right?is there any ways to change the battery if the battery power is low?
1,443
Hello I am new to the PLC programming, but I am trying to learn. Good for me is to learn also on existing examples, created by experienced...
2,820
