Panasonic FP2
Sep 2015
Coffs Harbour
Hello,
Just hoping I can get a little help
Got a FP2 Panasonic, and having trouble with an output coming on.
Looking through the software, all logic is sound to actuate the output. Output will come on very briefly, then turn off (milliseconds)
If I force the output, it will stay on.
I have changed the code in the program for example if Bit 1 is on, then turn on output. Still no luck. I'm hoping that its hardware failure, card or back plane.
Anyone had any issues like this before??
Thanks in advance
Joe
It sounds like you may have a racing condition. I would put the line of logic that turns the output on at the end of the program and run it. If it works normally there then somewhere in the program you are writing to the channel.
Hope this helps,
Regards,
Garry
http://www.accautomation.ca
I would suggest you print and attach a .pdf file, plus zip and attach the logic program to this thread. That way anyone with the software can review and offer edits or those without the software can look at it and recommend changes needed.
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,739
I'm working with a Customer that has 2 Panasonic FP2-C2 units. I'm not exactly sure what this even is... Is it a PLC with motion control or just...
1,553
Hi all, Im have a problem with my Panasonic FP2, (FP2 16K, 10970 steps) in the system registers, "Hold on/off (5-14)" the data range is not...
1,389
I'm sure one of you fellow freaks know what I need. I have a NAiS PLC with FP2-C1 CPU. I need the programming software for this. The sites...
5,130
hi everyone. i'm working now with panasonic PLC. The machine is OE, so I uploaded the file using FPWIN Pro 7 but when I open the program and try...
662
