Panasonic servo with Mitsubishi FX3U
medkhai
Sep 2012
bangkok
I am using servo for the first time.
We use PLC Mitsubishi FX3U-48MT which has transistor outputs.
The servo driver is Panasonic model MADHT1507U, together with motor MHMD022G1U.
What is the best way to communicate between the PLC and servo driver.
My application is a 1 axis linear slide for positioning.
In the brochure of Panasonic driver it says " Multiple control
features such as pulse, analog, and network technology in real-time communication "
I know pulse train is simple, but in the manual for MINAS 5, I cant seem to find where the pulses from PLC would be connected to the servo driver... where are the pulse train inputs on the driver?
I think they go to the parallel connector, but if somebody has experience with these drivers, please help.
Othwerwise, is there a better way to communicate from the PLC to the driver?
Med
There are two main options here that you suggest.
If you use Pulse Train then the speed and positioning is controlled by the PLC
- do you want this? This is normally reserved for stepper motors
The Servo is usually far more accurate
So the PLC only tells the servo to start
Go home. And call several predetermined programs.
- positioning speed torque is a programmable closed loop system
Hi I have a Panasonic Minas A5 servo drive trying to test in free run a Panasonic A6 servo motor, But as there is a mismatch between the motor...
1,674
Hi. i have a Panasonic servo drive running in position control mode. i need to increase the speed of the servo motor. which parameter i can look...
1,561
Hi, Anybody knows the pin out detail for RS232 Communication cable for Panasonic MBDHT2510 SERVO DRIVE (X2 PORT). Model no. of cable is...
2,222
We have a customer that has acquired a couple of these servo drives, but with a limited manual. Google searching brings up a couple of sites, but...
2,251
I have bought a PANASONIC servo model MHMD022G1U from the Panasonic datasheet it says its 200V, 200W Once I received the motor it has a sticker...
2,217
